Ok, I did a little bit of research on the matter.
What I think I'm going to get/do
Billet rod & flywheel.
Governor delete (obviously)
Champion rockers/hardware (hey, it's what, $30?)
Stiffer valve springs (poundage not yet decided)
Black Mamba Jr. cam
Mikuni knockoff carb (any particular model you guys have in mind?)
Thin head gasket (probably straight copper, haven't decided on thickness).
I doubt I'm really going to do much in the way of head work. I might clean up the intake & exhaust ports a little bit, but that would probably be the most done.
Just want to build a peppy, reliable 212 :smile:
Any recommendations?
You must remove the governer once you decide to really speed things up.
The parts inside will break....
Use G200 18 pound springs with the Momba Jr
Nothing gained from the champion rockers are this point why use them unless they are free?
Use a real stock GX200 head gasket its about as good as you need.
A PZ22 carb is probably the best of its kind for this aplication ( in a slide carb )
But there are many other carbs that will work just fine if you get an adaptor for them.
I prefer to have something I can adjust on the go with a float in it.
Your preference may be different, but do not go over board and buy a racing tilly or race cars unless racing is your only intent.
Any decent small engine car can work for you just don't make iit too big 22mm is your upper limit.
There are adjustable jet kits and bored version of stock carbs that are well behaved.
There are many options...
Trick of my own.....
I use a Tillotson racing carb intake manifold with a techumseh Series 3 carb.
This is both bigger and better performing than a stock carb but it idles and has easy adjustmens.
Your choice depends on what you intend to do with the bike
