Nice irony you got there.
What I said refers to the gear that is on the crankshaft. It is a light press-fit on the crankshaft. If you heat it up a bit, you can turn it on the crankshaft. There is a tool out there to do it correctly but it's wayy too expensive($189.99) Home rigory can do it just as well.:thumbsup:
What [MENTION=43506]trinik7597[/MENTION] said is to buy a billet aftermarket cam. This way you would be able to turn the gear on the cam. The gear on these cams bolts on to the camshaft. the gear can have slots or different holes to adjust timing. Be aware that these cams are a bit more expensive and you would loose the compression release. You could say goodbye to your pull-starter if you're running high compression.
The billet cam idea came from an old flathead trick. Builders used to torch the stock cam red hot between the cam gear and the closest lobe and physically twist the cam in a vise.
Hope this cleared up the confusion.:thumbsup:
