im not sure how much of a weak link clone rocker studs are, but i used honda studs for peace of mind. maybe somebody can chime in about the strength of clone studs and how well they hold up to say a 26lb spring. i know they will hold an 18 lb spring no problem. but 18lb springs coil bind fairly quick.
i just didnt want any problems, thats all. like i said, now i run raceseng shaft mount rockers, so i have zero issues.
the champion rockers you mentioned in your first post are also a good rocker as well. many have used them with great success, and are a very good choice as well.
with so many options out there, its almost impossible to tell you what you need. its all really up to you.
my friend runs the isky black mamba with stock stainless valves, champion rockers and 26lb springs like you mentioned. he also lightly ported his head, (mostly cleaned it up, opened it up a bit, smoothed the ports out, i.e. removed sharp edges, etc) we also milled his head down .065 to get a smaller combustion chamber, then used a stock .045 thick gx 160 head gasket with it, and a .020 longer con rod. engine runs very well, not a real screamer, but runs really good, and pull starts fairly easy with a mikuni 22mm carb on it. his static compression ratio is 10.3-1 and runs on 91 pump gas all day long.
