Hmmm. The ARC rod for my Tec doesn't use bearings...
I started thinking about a roller bearing for the crank end of the rod, but then you have to harden the rod journal, and have a steel rod with hardened journal....
Probably couldn't have a split in the rod end or the rollers would not ride over it well. And since you can't separate the crank, not gonna happen.
