Thank you markus,
I did read that write up of yours yesterday. I was unsure if a special Rupp only part was needed to attach the governor arm to the butterfly in the revised location of the carb. It is a true NOS engine, never had oil in it. I will seal that lower fill well.
Yea that linkage stayed the same so no problems there. I just looked at an NOS but damaged 1985 552200J I have and it has a single rear oil fill only on it so you may be good there, My engine should spec out the same as yours in that respect, it was the next revision to that block number (to electronic ignition). They did not use the letter I as its to easily confused with 1.
Forgot to note as well that slanted engines used the same amount of oil as as standard horizontal engines did, so they (the 20 degree slanted) came with dipsticks to check the oil level. So dont fill the oil up to the threads on a slanted like the paperwork that came with the engine states as its too much oil in the crankcase unless you put the oil in when the engine is sitting level.
and if you really want it to look like a true factory slanted application engine, the rear oil drain plug was an allen head, not the standard square head, no matter year, engine size, or brand bike it was on. its the little things :thumbsup:
