A search did not turn up too many hits.
So question:
Those of you that do put larger than 25mm valves in Clone heads. How much can you bore from the stock seat before they become a weak point. I read 27mm quite often but lately I saw something a bit bigger at 27.5 on something. What do the experts bore the seat out too is what I am asking, and if you go larger how much of an interference fit do you need on these heads ( .005 range? )
So all things being equal what difference in flow does the leap to 27mm intake have or is the porting on the clone head the real limiting factor.
BTW this is a cut and paste of the same question I posted at Bob's 4 cycle.
Seems quite reasonable to ask in both places and see what those more clever than I have to say.
In particular I would like to hear from you Olajoe808, your very tight lipped on these subjects.
So question:
