Small Flo jet
Hi All, trying to find a aftermarket replacement for a small Flo Jet carb, the ones that I have found have different mounting holes ,any recommendations?
Thanks
Minimichael
How are they different (size, distance, angle)? Can you post a pic? I've got an old one at home I can check. Ones online all show same flange holes at top and bot.
Please measure your bolt holes, center to center.
I assume it has a large center hole and two smaller bolt holes on a diamond pattern.
I might have some carburetors with a bolt pattern smaller than what seems to be most common.
Still hunting a carb for the hit/miss engine on the little locomotive?
