I went to change the plug in a 1976 HS50. The CJ8Y that I took out had a much larger thread than the new CJ8 that I had . I put my glasses on and could see there was an internally and externally threaded "sleeve" on the old plug.[It is not a HeliCoil] The head had a larger threaded hole than the other HS50s I have. The hole was straight and well machined. The HS50 is original to a Heald VT5 I have that is in excellent condition. I don't believe the plug hole could have been drilled and tapped without removing the head. It seems to me that a new head would have been easier and not cost that much if a prior owner had stripped the plug hole. Could Tecumseh have salvaged heads with bad holes in this manner? Anybody have any thoughts?
PS- The sleeve seats against the plug gasket. There is very little of the gasket beyond the sleeve to seat on the head surface.
