So we compression checked it. 100psi! Still no run. We put a brand new carb on it thinking that would help since the old one was leaking through every gasket possible. Didnt help. Both carbs shoy fuel out the air filter when you tried to increase the throttle to help start. Any ideas? Spark plug is gapped properly.
You called it. My father took the flywheel off and said the keyway was in two pieces. He forgot to take a picture. I'll let you know what he says after he fixes it. Thanks so much! I truly would have been lost without you
