Thank you ole4, what i did, and found out, was, i installed the cam and then checked the lash. it measured OK. i did not measure the lash after installing side cover, OPPPS! no lash found, zero, hence the easy pull. so a little work on the lifters, and now great compression. valve lash now at .007. will be running soon.
