Tecumseh Flathead Service Manual
Here's a link to the complete Tecumseh L-Head (Flathead) Service Manual. By setting the page size to 100% it's just like reading the book....maybe even better because you can use the search box at the top of the page to put in key words.
http://www.smallenginesuppliers.com...cumseh_L-Head_Engines_Service_Information.pdf
If you still want a paper copy to get your greasy fingerprints on just hit the print button....you can print out individual pages or all 124!! ....:thumbsup:
this link was very helpful especially the crank size chart to figure what i have by dimensions since the housing with model numbers were gone when i got it
Steve73
I have a h50 and purchased a cheap replacement carb. This was a life saver as I installed the new carb and needed to know the procedure for adjusting the new carb. Engine purrrrrs like a kitten now! Thank you...
Fourtogo
How does the electric starter deal work . It’s got a AC plug on top of engine with push button also.
PatrickCraik
Plug it into a hot extension cord and push the button. They are convenience starters for equipment like a snowblower.
Yep,I needed mine one year. Forgot to drain gas in the spring,it went bad even with stabilizer. Drained all I could without dropping the bowl. Pulled my arm off before giving up and plugging in electric start. Once it cranked fast enough to purge the old stuff it fired up. Lifesaver for a sometimes forgetful and too busy a guy
PatrickCraik
BTW,I've since been using ethonal free gas in the toys and yard equipment. Its available @ Murphys in Michigan. I Have a full tank in a car stored for 7 months now. Started right up and runs great
Harquebus
If both of those links in post #1 and #6 are 404 but you can still get to Oldminibikes, it might behoove you to download it so you won’t require internet access to view it. Printing it out is a great idea, even if you have to resort to bringing the file to FedEx (formerly Kinkos) and having them print you out a handbook.
I attached a downloadable pdf file to this message. 5.1MB 121 pages.
