only problem is that when i got the motor, somone removed the entire arm. and plugged the hole with a bolt. so i guess i need to fab up a false arm, unless someone knows how to rig something else up?
I would ditch the motor but it is original hs40 tecumseh with lighting coil, and it has 80 psi on first pull and 100 psi on 2nd pull.
