Timing problem?
Hi guys. This one has me a little stumped. I have an Intek 6.5hp horizontal engine. When I got it, it would pop but not start. It sounded like timing to me so I pulled the engine open and checked the timing marks. The cam was 180 out. I put the cam back in the correct place and it does the same thing. This engine looks like new inside and out. I pulled it apart and checked the valves and springs. Everything looks like new. I have not pulled the flywheel off yet, that will be my next thing. This thing pulls like it should, with no obstructions, like I said, it looks like new. Any suggestions? Could I have the marks off on the timing? The cam is plastic and the lobs are plastic mounted on a steel shaft. The cam gear has a little square molded into it with a mark so I am hoping that, that is the timing mark. I appreciate any suggestions that you might have. Thanks.
I do not believe the cam on a one cylinder, flywheel magneto-fired engine can be installed 180 out, but I might be wrong.
I would certainly remove the flywheel and check the key.
Flywheel is what determines ignition timing. Check your flywheel key.
What they^^^^^ said. Very well could be sheared or "partially" sheared (bent), which WILL directly effect the timing. Also, make sure that the flywheel is torqued down properly using a good torque wrench to the proper (published) torque values. If it was too loose that could have caused the flywheel key to be damaged.
Michael
Check Your Fly Wheel Key and Replace your Spark Plug with a New Champion Spark Plug! Sometimes the engine will backfire and won't start because the spark plug was bad even though it looked new and I put a new plug in and it fired right up running smoothly.
Tom
