The shorter 1 1/2" spring was the rebound spring. It kept the bushings from 'topping-out' when when the wheel left the ground. It should be on all tote gotes with front suspension. A bushing driver is the proper tool to install the outer race of the timken bearing, but anything round and close to the inside diameter of the hub can be used to drive them in. Make sure to drive them in straight.
