Utility engine powered ATV from the 80’s?
MJL
Talked to someone recently that said they had an ATV powered by a utility engine (flathead Briggs?) with a centrifugal clutch, probably a solid rear axle. Basically a go kart made to look like an ATV. The kicker was that it was a CocaCola promotional item and was all decaled up with CocaCola, unless some kid did it themself. Ring any bells? Just thought it would be interesting to find out more about it.
Bird engineering (phoenix engineering in the mid 80's) 3 wheelers were used a lot for promotional giveaways IIRC They were usually based of the "Romper" They had a model called a stomper too though
MJL
Thanks! I’ll check with him and see if that was it. I couldn’t find a Coke version, but did find a pic of what looks like a Mountain Dew model. IMG_0768.jpeg
