here is some info i found on them.
The model 6S was manufactured from 1949 to 1957.
This engine used an L-head design.
It was equipped with an adjustable pneumatic governor.
The air cleaner on this engine is an efficient oil-bath type.
The type L, (vacu-jet) carburetor was used on this model.
The exhaust is aspirated through a 1/2" NPT threaded port.
Gas tank is mounted externally to the carburetor.
The oil sump and head are cast aluminum.
The engine block is made of cast iron and utilizes fins for air cooling.
Piston and connecting rod are made of aluminum alloy.
The crankshaft is counterweighted and drop forged.
Displacement: 6.28 cubic inches, 2.00" bore and 2.00" stroke.
Rated at 1.20 horsepower at 2200 rpm.
Rated at 1.48 horsepower at 2700 rpm.
Rated at 1.60 horsepower at 3200 rpm.
Operating speed range: 2200 to 3200 rpm.
Idle speed: 1750 rpm.
Lubrication: Pump or dipper type.
Ignition: High tension magneto.
Spark plug: 14mm - Champion J8 or equivalent.
Oil capacity : 1 pint.
Gas capacity: 1 quart.
