Hello everyone. I recently picked this up and looking to get it tearing around the yard. I have no idea what it is, but quite possibly cobbled together.
I think this engine was originally gold and the frame was originally red
First off It's a sears engine 143.8200 Doing some homework brought me to this thread https://www.oldminibikes.com/forum/tecumseh/72570-lauson-tecumseh-engine.html
It pretty much matches that engine. I have a hunch that this is closer to 2.5 hp as the bore of the carburetor is only .5" dia the inlet at the block is .8"
Anyway, anyone have any details or photos as to the one piece of throttle linkage missing? There is no linkage from the governor linkage to the throttle butterfly shaft. Some of the other Lausons I've seen have a second connection between the block and the carburetor. This throttle shaft does not go out the other side. I have one broken wire that kinda leads to the throttle butterfly but appears to run into other items of the throttle. The linkage is so fragile.
Also I have a problem with the brake. The inner shoe is broken. I'm measuring the diameter of the shoes 4.25" and the drum 4.375" Can I find a brake or shoes that will work for this with the original drum? there is a picture of the cast outside leaning up on the engine.
Google album here with two more photos
Thanks for your help,
Nate.
Nate.
