Purchased this recently and just getting into Mini-Bike projects for myself & my kids. I would like to know what I am dealing with so I can figure out which direction to go with.
The bike is a bird, its it later 1970's version at that point they were mostly called sprites, engine is a bit newer you should be able to find the engine specs on a decal located at the back of the recoil shroud, under the throttle control mech and carb that is the actual Tecumseh codes. If it s not there you may have to use other decal on the front which is off the generac equipment the engine is originally off and try to hunt out the manual for that and see if you can get an engine code so you can order parts if needed.
