will a 5hp briggs tank fit a 3hp?
dbone
New Member
ok guys now im building another mini bike for my kids to use and follow me on the rocket, question is they want a old school looking mini, flat black paint white walls and polished mags.
i have a cool old briggs 3hp thats a pull rope starter runs like a champ, but has a small fuel tank, will the larger metal fuel tank off say a 5hp briggs work on it??
yes buy i think that you need to upgrade your carb to the 5hp or you might be able to get extensions if it is the the carb mounted on gas tank type.
If you cut the pickup tube and extend it with silicone hose it will work. umodified it will only draw as much as the stock tank holds.
minidragbike
Supporting Speed Nut!
You can do that.
My friend Drew is the only guy I know that can pull the tube out and put it back in with no problem. I have tried it over and over but I break them every time.
