Hi there,
I have just purchased a few different parts from affordable gokarts but im not sure if this cam would be ok on a stock carb....
affordablegokarts: Cam, Custom Ground .265" Lift, Modified
As the duration is longer on the intake
The engine seem very sluggish and underpowered and im thinking it might be the cam spec of engine as follows....
Every other fan blade cut off (for less drag)
8degree advanced timing
Spark plug indexed to exhaust
Spark plug gap adjusted to 1.15mm
18lb valve springs (gap adjusted to 0.5mm inlet 0.7mm exhaust)
0.10inch thick head gasket
Flat top pistons
.265" lift cam (236 duration on intake/exhaust)
Long billet rod 3.313 (.10inch longer)
14cc cylinder head with ported intake/exhaust
custom exhaust
Honda aluminium flywheel.
What do you guys think...
Flat top pistons
custom exhaust
