No keys and no crank no start.. The wiring diagram shows a two wire ignition switch and my ignition switch has four wires. I could not work it out in my head that white was the switch power wire as it ran from ignition switch to the relay but didn’t grab power for the switch anywhere.. Stuck the tumbler in a vice and broke all the pins with a flathead and it worked! I backfed 12v power into the white wire to power the switch turned the screwdriver to on AND finally! 12v power to the brown wire. Turn it off and no power to the brown wire. So the ignition works as the factory intend. Now that I have power and a working switch the brown wire gets 12v power and runs to the neutral light. It also grounds the two brown wires off the lights together to send power to the starter button. It all made sense when I twisted the ignition switch with a screwdriver and then found 12v on the brown wire.
