Hey AJ,
I was just going over your post and sorry I didn't keep up with your progress I whish I would have chimed in, with the wax you are using it needs to be at least five or more coats and if I read correctly you are using polyester gelcoat with epoxy resin in your lay up, you need to use the PVA and you need to apply if as fine a mist as possible, with at least three or more coats or until you see a greenish tint on your mold. PVA it is water soluble. With that said when you lay up the next part leave extra amounts of wet out glass at each end of your part, when you go to remove the part from the mold use a couple of wooden wedges to start the separation and then submerge the whole part and mold in the waterand it will dissolve the PVA and release the part without damage to the part or mold. I will pm you some info.
C
