Hello! SO i have been playing with my Baja Warrior 200. The engine is now pretty built (milled head, ported, cam, rod, flywheel, vm22, flat top piston) and i am having issues with the TAV2 torque converter i installed. It is a china version of the TAV2. Currently have the stock weights and springs in the drive. Changed to the yellow spring in the driven. The engine revs to about 4500, and then you can tell it starts to shift already. Then the RPMS drop some and seems to get flat. Looking at the clutch after some runs i see a slight black ring on the drive about half way up. Makes sense that it is slipping there and goes "flat". I ordered white garter springs but they are a touch longer than the ones in my clutch and wont work. Seems odd. So before i go order comet weights i was hoping to get some advise. Thanks!
