This is my setup:
2 stage header
22mm mikuni and UNI filter
mikuni fuel pump and pulse
18 lb valve springs
.275" custom ground cam
billet rod and flywheel
flat top piston and file fit rings
indexed spark plug
I am running a 12 tooth clutch and a 72 tooth sprocket. My question is, can I go full throttle for an extended period of time or can my engine explode? I know valve float will be my limiting factor, but what will happen if I go top speed? I am wondering because I want to see what my max speed is but I am afraid of ruining the engine. Am I being overly cautious?
2 stage header
18 lb valve springs
indexed spark plug
