Here is a pic of a brake band bracket off a Montgomery wards 525. In the pin is a small hole, should there be a cotter pin in there to keep the pin from sliding out, I'm assuming so, what does yours have? Thanks
I follow you on the brake band, but if you look closely at the pin, you'll see a hole, I'm thinking there should be a cotter pin there to keep the pin from sliding out, once its installed to the frame of the bike, is that what yours has?
