’67 Taco 44. What can/should I do regarding these swing arms?
The questions I have are:
1. The axel bolt slot is not parallel. Should it be? Should I heat it up and try to bend the opening parallel?
2. Has anyone made some sort of bushing or is the bolts without anything sufficient?
3. Should there be a brass washer or something between the frame flange and swing arm?
4. The bolts and nuts are thrashed. Is there a recommendation for replacement?
5. One bolt hole, see pic, is worn into a dish configuration. What can/should I do about that?
6. Any other suggestions/recommendations are appreciated.
Thank You. This is the start. Next is the jack shaft and then forks.
