11 year old grandson has stock motor, works ok, need a little more power. will the 3 1/2 briggs help much? don't wanna do the 212 predator. any advice? thanks in advance :thumbsup:
I have a newer ( 2/90)solid state 3.5hp tec that I can't find a part number for the rings... all I come up with is 28986 and those won't fit..this piston takes thin comp and scraper rings with the spring type expander on the oil ring.. 2.5" bore
it doesn't have an actual "model" number, just...
Hello again I have gotten my 1959 3 1/2 briggs running good. It will sit there and idle until it runs out of gas, but it doesn't like to start with out some type of prime. I have to give it a shot a starting fluid (i know, I know) to get it to catch. I am not sure what I can do to make it start...
i just picked up this lil 2 1/2hp B&S from a guy up the road from me. $20, not bad. he said he took it off a lawn mower 25 or 30 yrs ago. it turns over, not sure about spark and it needs gas. ill see if i can get it started in the a.m.
picked up a 3 1/2hp briggs today. it was for a coleman power washer. model 91212. i need to hook up a throttle cable to the slide under the tank. has anyone done this on this model. it seems different than a 5hp i did this way. according to the numbers it was built in 1994.
