Built up a briggs with a 107ss cam with corresponding parts, timing at 34 degrees (alky hl342 tilly) head shaved flat with slight valve pockets cut for .04 clearance with gasket. I've broken a few pull starters and almost my arm before so I don't mind a bit of a challenge but I want a fast bike...
raptor III cams seem to be common and cheap. what can i expect if i put one in a regular briggs 5. will it even work? are they a mild cam or will i need to make other modifications. I realize it might need heavier springs but dont plan on running high rpms . i dont know jack about these racing parts
I am looking for another upgrade to add to my mild built clone. As of now, I have a .265 cam and 26 lb springs in it. For those of you that have experience with cams, what have you found as the best one? I am looking for a cam that pulls through alot of the power band. But would like some...
Traded into a clone that is supposed to have this cam;
Cam = Dyno “CM” Modified - .275 lift at the cam
Intake duration is 236 Exhaust duration is 236
Cam has serial number and "L XL 2" stamped in the face of the gear, mechanism still all intact on the rearside of the gear, unlike another...
I just got a used 308 cam from a guy off the karting forum for my clone, everything looked pretty good until I ran my finger nail over the one lobe and felt something, I looked close and it's a hairline crack right about where they added to the original lobe like the weld didn't penetrate into...
i have searched for a 3hp cam and cant find anything im sure they dont make them if anyone has any info let me know im building a bike for my 7 year old son and a 5 is too much for him i made an intake for a mikuni for the 3hp and hogged out the ports a cam would made it perfect
building up a briggs 5hp and have the chance to buy a 311x cam with lifters and new springs, but can't find any info about it, does anyone know what the lift might be? any help would be appereciated, thanks
