like the title says, i need a gx200 clone, must be complete and would prefer a stock one, i dont need the exhaust too, so if you have one with out it, ill take it. need one asap thanks
Yet another thread about the HF 6.5, but why not when it can save you some money.
HF has there 6.5 clone engine on clearance for $74.97 6.5 HP Gas Engine - Horizontal Shaft, OHV, use the 20% off coupon and it's $59.98 plus tax, here's the coupon Coupon Display
BTW, just in case you're...
I wasn't going to put this in the wanted section. I thought it would be a good place for some advice and offers anyways.
I bought the 6.5hp clone that everyone was grabbin up for 100bucks. It sure sounded like a steal. So the engine will be arriving soon, along with some tools...
Harrison Wildcat for sale with built up 6.5 clone that = about 18 to 20hp on gas. The motor has just about every after market part in it that you can think of except roller rockers.
About the bike
Seat and handle bars are like new. Has band brake on the rear wheel. has big brake lever. jack...
Do any of you guy's use 2 gaskets on your side cover? It looks like a gap, i know it is on right, and tightened right..:shrug: Looks strange looking down at it.
pulled gov today went fine. when i was making a carb linkage i dropped the WIRE in the flywheel house i pullid it slow hoping iw would fall out. opened it up replaced shroud , now i have no spark. things look fine the coil looks spaced is close { not feeler gaped} with flywheel . im loosing...
Well im selling my azusa after riding it today. I dont feel safe when i get speed wabbles at 20mph. it has a clone with.......
Honda OEM aluminum flywheel
ARC Billet flywheel.
Mikuni 22 with a maddcarson custom air cleaner setup
18lbs valve springs
4 deg advance timing
new plug
Frame has been...
I'm sure that I could do a search, but I like conversation. I'm looking for opinions on what clutch to buy, pretty much for anything over 10-12hp. Not really worried about cost as much as reliability and the cool looking factor. Reliable first, tho. Thanks in advance. Scott.
Hello I purchased a MQ Power JF 200 clone. I had an extremely difficult time starting this engine whether cold or hot.
After reading I found that an idle jet drilled to 0.025 is the fix. Here is what I did and the engine starts very easily not and doesn't need choke or gas when warm...
