Hello-
My son and I are working on getting an old Sundowner going, we posted before about the trans and have since gotten the bike to run! The next hurdle is the front forks. They are VERY loose, I suspect from degradation of maybe a bushing that should be inside the forks. It has probably...
I'm a new member, so some of my terminology might not be so accurate. Seeing if there are any front forks that would work for me. I have what I was told by the seller as a 1968 El Tigre. Forks that came with it appear to be welded back on numerous times over the years. They don't make me...
71 Speedway Fork Rebuild... I need some stuff.
Please Help... Wanted/Looking For:
Plastic Retainer Rings - Mine Are Broken
Springs - One is Rusty/Broken
Dust Caps - One is Torn
I have a 1971 Speedway Scorpion front fork rebuild in progress. The hard part is done as you can see... Someone had pumped grease into both sides!!! What a freaking mess!!!
PLEASE HELP!!!
I need plastic retainer rings that fit to rubber. As you can see, mine are...
Does any know where can get a front fork assembly for a Heald Super Bonc VT-8? I am in disbelief still. I just bought the bike and it was shipped to me in pieces so I did not have the opportunity to ride it. The bike looked to be in outstanding shape. When I took the spring boots off in...
