performance mods
  1. smalls415
    New guy with some questions
    Hey all, Newbie here!!! so just my second post, in need of some answers again. Something seems to be locking up on my Colemanbt200x when I let go of the throttle. It brakes itself to almost a stop, not in a jolting kinda way, more like a slow self brake, like a car going down a hill in a low...
  2. C
    More power!!
    Hello, I've got a Coleman ct200u with the stock clone engine. I added a .035 rejet kit, hi-flow air filter and ARC racing adapter. Also have a custom straight pipe. I feel that I need some more power, for what i'm doing with the minibike. My friend did a pretador swap and now he almost beats...
  3. TankforGod3
    Old style head on new style engine?
    Aight bros After poppin off the valve cover on my hemi predator and seeing the rocker arms on it I was kind of sad that i couldn't find that style in 1.3:1. I wondered if the old style predator head would fit my engine, or even a smaller gx series head, but I read somewhere that the old style...
  4. R
    Need carb for 5hp briggs flathead
    I bought a 94ss cam and 22lb springs from dyno cams and installed it in my motor. Stock crank,rod,piston,valves. slightly ported intake and exhaust and now i cant get it to idle or run very well. (timing is definitely correct). I have the stock pulsa jet carb with a fixed jet :/. What can i do...
  5. briggs intek
    briggs intek 6.5 hp i/c
    ok i bought an intek 6.5 hp briggs and stratton and it did not have a govener so if i run it past 3600 rpm and float a valve how much of a risk am i at of punching a hole in the piston? and if there is a risk were can i get higher pound valve springs/cam/pushrods? i found peple saying animal...
  6. S
    HF 212cc 6.5 hp Predator Engine Mods & questions
    So I got the motor from a friend and it ran but it had been sitting for a while in the rain and shit so it needed to be cleaned up.. I cleaned the carb, than I removed the governor and put a screw in the top of the block.. Next I began to get a throttle linkage going.. Put in a new return...
