Hello, new guy here. I have a gc 5hp from a pressure washer I was using for a go kart for my kids. It's low idle is terrible, and just dies. It had been sitting for years. I figured the jets were clogged so I blew them out with some compressed air. I will need to pull them completely and clean...
I currently have a HM80 that is going into a minibike project and have a few questions.
In general I know that removing the governor isn't the best idea, but how do these engines fair if the governor is removed?
I know I need to remove it completely from the inside of the case etc. Is...
have a 5hp Honda from a power washer on this ol bike, can I remove the fuel pump and use a gravity fed tank mounted up top in front of seat?
thanks for your help.
The photos are of a nearly 40 year old Comet clutch (bell housing removed) off of a Sears Roper 2-speed jackshaft assembly. There is visible rust in various locations, including the 2 springs, I would like to soak the entire thing in "Evaporust". Any harm in doing so? Due to the age and rusting...
I've seen it stated in various threads that the reason removal of all parts of the govenor from the crankcase is that they may become loose and fall into the crankcase during operation? Has this actually happened to members here. I'm getting ready to use a Honda GC190 motor in my first Mini...
I have a new 6.5 HF clone,
I just de-governed it and removed the low oil level sensor.
What size bolt or plug do I need for the hole in the block? ..where the sensor wire went through.
I'm at home, & the motor's at work,..
your answer will save me a trip across town to get my motor and...
I want do some tire swapping on some spoke wheels, easily doable here in the garage or is this best left to the "pros"? I don't have any tire tools except for a plastic set for a bicycle, and I doubt they are gonna cut the mustard! Is it worth buying some tools?
A few Years back I got ahold of a brand new Tecumseh 6.5 ohv power sports engine. It was on my Atlas for a bit with exhaust and intake.
Whats the procedure for removing the Governor on these engines? Also is there any other hop ups I Can do to it?
I Would just trade it off for a Lifan...
