woes
  1. RustyRedneck
    Fox Sprite brake woes
    As some of you may know, I'm working on my Fox Sprite mini bike for the 2017 OldMiniBikes Build off. Anyway, I've run into a little snag. The rear brake pads have separated from the shoes due to rust. I'm curious if you guys know where I cold get new ones or how I can reattach the old ones. Thanks!
  2. RustyRedneck
    Montgomery Wards mini bike chain woes
    Hey fellas, I got a Montgomery Wards mini bike years ago for Christmas from my grandpa, rode it for a while, parked it in the shed and haven't done anything with it for years. Lately I've been thinking about it more and more and want to get it back out this spring once it warms up around here...
  3. U
    Governor Woes
    Hi guys. Just yesterday I swapped a 6.5 hp Champion engine onto my Fox. I'm having one problem though: as soon as I start it it revs to the moon. If you hold the governor linkage back, it idles fine. The governor doesn't want to return the motor to idle. I tried adjusting the governor by...
  4. Rapidrob
    Inner tube woes
    I cannot keep an inner tube from failing in my 4.10 tire for some reason. The tire is new, and smooth inside. The rims are smooth and shiny inside. The rim is split. The inner tube is inserted into the tire and slightly inflated. It fills the tire and is not pinched by the rim halves. I inflate...
