And you can have swirl without a massive ramp you have port shape combustion chamber and boundary layer also. If you want to get picky think about lift at the valve and valve seat angles that will take advantage of low lift or high lift flow 30 degree vs 45 vs 50 ect. If you plan it out for what you have you will have a real firecracker. And I am just touching on this if any of the builders want to let their secrets out they will they make it look real easy but they are very good at making big power out of a utility engine.
I don't think too many people are going to open up and say exactly what they do.
So I have to continue to work through exactly how I will deal with this new head.
I appreciate your comments, and as I mentioned I have seen some rather interesting work done on one 210 head but that is it.
The only thing I can think of to put any swirl into this would be done in the bowl.
Probably how to shape one side and how deep to cut down VS the other side.
But as I you said if any of the builders want to open up and talk I am all ears.
Today did nothing but push some guides on an old 22cc head casting.
This is preparation for the big push on this new head.
But I am still up on the air on what I will do other than round off the short radius for now.
The only thing that looks like what I want to end up with is the big belmitt head.
Its not swirly and its a straight port with a quench.
