How would you do it? How reliable would it be? At what rpm would the modified engine make that hp? I have built a clone with all the goodies-- 24mm Mikuni carb, header, billet rod, 14cc head (pocket ported), billet flywheel, flat top piston, SS valves, 1.3:1 rockers (stock cam), 18lb springs (shimmed), chrome moly push rods, side cover bolt kit, head bolt kit and a .010 head gasket. Is this set up close to 16 hp?
I am looking to use one of these engines in another application, a mini airboat, and am looking to get 16 hp at 5000rpm or less. Is this a do-able project? I would be willing to do build another one like above if it fits the bill. The reason for not just buying one of those 16 hp engines is the weight factor, it would sure be cheaper. They weigh 83 lbs as opposed to 38 for the 6.5. Anyway, your thoughts please.
