197? Tecumseh lighted HS40
Runs great. Just took it off the shelf from getting it running last fall. Filled with gas and it fired right up. Has the long shaft that is keyed and tapped. Tested coil today and you can see by the video and pics it's working also. $300 plus shipping. Doesn't come with a gas tank. I did install a kill wire.
https://vimeo.com/178829683
Ding Ding
hi
would that motor be correct for a arctic cat climber ?
thanks
garth
The correct engine for a Climber would have the recoil studs rotated in a diamond pattern, as opposed to the square pattern on this engine. Other than that, it's a lighted HS40 that looks to be in the 71-73 year range.
That is a Fox specific HS40 these are the numbers for that particular engine combination #55266b
these are the numberplate and shroud/plate from the bikes shown below for verification (orange was a 1969 black was a 1970)
