Gumpit...You have the polarity reversed from the charging coil. When you rev the engine it drives the battery voltage down to near nothing. Reverse the wires from the charging coil so +&- are working together instead of bucking against each other...problem solved. Also, if the battery was connected backwards it would do the same thing.
