Whats the trick to compressing the spring to install the split keepers..? Also is it normal for the inner spring to ride on the head that supports the valve guide vs down in the spring pocket like a normal spring....
I normally cut the spring pockets on the head. This usually make the material around the guide thinner. But it still works fine without it being cut, just make sure your springs are oiled for less heat and friction.
Yes it should sit on the bottom. You may need to do some minor grinding on the head to make it work. I thought you was saying it was sitting on the bottom, but rubbing the guide boss on the sides.
Truthfully I was/am kind of worried/paranoid about it, but Tim assures me its OK. I also read that he set someone else up with a similar build recently...
Especially sense I am planning on running it in for extended periods, or at least longer than a short little drag race.
So Minidragebike is your concern the additional spring pressure prematurely wearing the cam or just adding excessive uneeded friction? Whats the main problem with running a 55# spring with that cam shaft?
I just noticed Tim has two sets of dual coil springs. Is there a visual way to id the heavy dual springs from the light ones? And would the specs from the lighter springs be more appropriate for the Black Mamba Cam? My springs appear to be marked with green paint.
