is that a Jr flywheel from an animal or is it a flathead flywheel? if it's an animal flywheel the keyway is clocked wrong... do like Jeep said above.... if it is an animal flwheel and if you can get the airgap set right with the coil (not sure if the o.d is the same on both flywheels) then you will have to lap the flywheel good to the crank and set the timing, then lock it down without a key..
