Awesome! Just for a reference the housing is about 4-1/4"
I forogot to measure, but yeah, I'm sure it's the same.. The standard small headlight size.. I pulled it from a regular minibike light can..
It is a GE 6 volt sealed beam, two screw on posts..
I DON'T KNOW!!! :laugh: It won't show me a picture... :doah:
what does TSC get out their 6 volt bulbs???
no problem :thumbsup:
thats the same type as my arctic uses . too bad you did
nt need a 12 volt one man i got a box full of them new old old stock . like boxes rotten away from sitting on the shelf old :laugh:
I might be able to use a few of those.. AND some brazing work too.. :mellow:
Well if I understand correctly the HS40 is a 6v system correct?
I dunno.. I never measured.. I know I measured an HH60 once and it was 12 point something at a mid range rpm.. :shrug:
as far as i know they are thats what my climber would have had and the bulbs are 6 volt .
but i dont know all that much on the tec charging systems . maybe restorkid can give some more info on them :shrug:
buckeye if you can use 12 volt ones i can send ya some for a good price . ill try and dig them out and see how many i have .
ok ran out and was lucky to find them in the storage there 12volt westing house (well most are think ones a ge ) 35 watt 2 screw terminals on the back and like 4 1/4 to 4 3/8 dia .
I dunno.. I've noticed the 12 volt ones work pretty good on them, but I don't think they put out enough amperage to really blow a 6 volt bulb anyways unless you were really spinning it.. Someone should try.. :laugh: Hell they might be nice and bright.. I know all the electric start motors and riding mowers are all twelve volt..
