I was going to try to use briggs 3 1/2hp lifters in this thing, but haven't yet. Maybe if I have a problem with the lifters on this block, i'll try it on the next motor. I've got a 90 degree angle air drill and was thinking about trying to carefully "free hand" it. I don't know if the drill would even fit in the block though, or if I could get the holes strait enough. Like you said, it would be nice to have proper tools to do these jobs... Anyway, their still holding up. The 2.8 block is pretty rugged. Steel sleeve cylinder, dual ball bearing crank. They just skimp on material, like the lifters, valves, crank. The rod looks beefy enough, except the tiny end cap bolts look kind of weak. The piston is ok. Rings look kind of rounded on the wear surface (I noticed a stripe in the center where it's been hitting). Still working on my bullet proof scattershield flywheel shroud. I'm using some scavenged seat belt from a junk car.
