Have a 1974 Kawasaki 75 MT-1B that has not run for at least 25 years. I removed the spark plug, grounded it and it had a very strong spark. The plan was to do a compression test. But a significant amount of oil was ejected out of the cylinder. Every time I kick the kick starter oil is forced out the spark plug opening. Where is this oil coming from? At first I thought that it was coming from the injected oil that is mixed with the gasoline, so I remove that oil tank and then watched the oil level in the tube that drained from the oil tank. The oil in the line has not moved. Could this oil be from the transmission? This is the first 2 stroke engine that I have worked on.
