Im working on finishing my Tri-Sport TS-110, I need to replace the bearings on the differential axle. I got the differential off trike, taken apart. The inner 2 bearings slipped off with little resistance. However, the 2 outer bearings wont budge. I tried tapping them with a hammer but no luck.
Do the slide toward the middle piece and off?
The hubs are welded on so id imagine they would slide to the inner part to come off?!?
Do i have to cut these off probably?? Any suggestions on how to go about this?
Also, i was told to put "Bentonite Grease" in the differential, is the - Tecumseh 788067C Peerless Transmission Grease - from OldMiniBikes Warehouse what i would need?
Any help would be great and appreciated, thanks
Heres some pics of trike and parts im struggling with
:grind::grind:
