Something I thought of. Maybe reconsider pulling the clutch off the crank. If only to replace the crank seal. Its real easy to change once the clutch is off. Its in a removable plate. Do the mag side also, once you pull the flywheel. You don't know if they have ever been changed and you don't want to fry your engine first run due to a 49 year old seal leaking.
