Those bicycle ones will actually work pretty great if ya do them right. They are usually pretty chinsy and some will break if you try bending them BUT some don't. It's a bit of a trick to bend them but what I will do is set the bike up on like 12 inch blocks under the tires, as if it's sitting there flat on the floor, Then get it all propped up at the basic angle you want the bike to rest at when it's on the stand... THEN you will be allowed to get your kickstand all bolted up there how it seams like it will travel nice and stay located well... A lot of the time they will have a notch in the mount part that you can just about line up with a slot in the motor mount plate... If you get your kickstand so it folds up and works nice and just needs to be the right length, you can slide you another 12 inch block over to the kick stand and see where the end needs to be... I like to mark it with a paint marker... (I will come up about 3/8 inch for bend radius) You can try to cut it off flat but I like to bend it outward so there is a little foot that sits flat on the ground when it's folded out and a nice tab to get with your foot when it's up... You can lock your kickstand down in a GOOD SOLID vice, and use the jaw as a radius and a piece of cheater pipe as a handle, and bend the kickstand over. Clamp the workings and stand itself downwards and the piece that is going to be a little footy up where you can put your pipe on. Don't cut it until you've bent it to give your self a LOT more leverage.
You have to be careful to make SURE you get the bend at the right orientation (roll) to the the rest of the workings up top so it lines up right once it is bent.. THAT IS Crucial as is MAKE SURE to start your bend up higher on the main arm of the kickstand about 1 to 2 times the thickness of the arm. THAT WAY when you bend it, it ads on the hight of the bent material, to the slightly too short main arm so it = correct hight.......
hmy: WOW that sounds like a lot huh? :doah: It's simple as hell though... HAHA!! Read the instructions a couple times, sit there and look it over good and think about it.. All you have to do is get it pretty damn close and you can ALWAYS ad a piece of rubber hose to your little footy to make it sit 1/4 inch higher AND be linoleum floor friendly, or tweak the bend in the foot to raise it some or bend the entire arm out some to lower it.... if you get it pretty close it will be fine... Try it once or twice and think about what you're doing and you will swear just building a kickstand is the only way to go. :wink: I COULD buy one on Evilbay for $20 that MIGHT NOT even be the right length, THEN wait a week to get it.... OR just BUILD one for FREE right now how I WANT the damn thing and be done with it... Is how I about always think... :hammer: I will get pics of the one on the Boonie tomorrow.. it's easy as hell with a bicycle stand, vice, hammer helps make TIGHT bends, cheater pipe, hacksaw or sawzall. :hack: And just think. If you build it in an hour you just made 15 bucks per hour, or however much you didn't spend on some Evilbay one :thumbsup:
