Okay, so after Joekd was kind enough to provide the crankshaft dimensions I was able to run out to Home Depot to purchase a 5/16-fine thread bolt. I am concerned because I could not find a 5/16"-24 fine thread bolt at Home Depot....
I am reposting 3 pics. The first showing the OEM crankshaft with the 2 small holes drilled at the top for a small pin that held the OEM clutch to the shaft (as reference). The second pic (trying to show the inside of the crankshaft) because there appears to be a small pilot hole about 3/8" already in there. And, pic #3 showing the same inside of the crankshaft (it's hard to get a photo of the inside of that bugger).
Question #1 - can someone please confirm this shaft is already tapped and drilled? Sorry for asking a 2nd time but I think my first photo post at the beginning of this thread was hard to see.
Question #2 - if this shaft is indeed tapped and rilled could my lack of understanding on Joekd bolt dimensions, specifically the -24 fine thread part be causing me to believe the bolt will not fit? When I try to insert the bolt its as if there are no threads on the inside of the shaft for the bolt to catch?
Sorry for all the dumb questions but at least I am trying
Thank you all. I will try to past the photos into the bottom of this post here:
