billet rod, meet black mamba cam.
So I've done a combination of about 6 of the hemi motors with stock, 20, and 40 thou longer rods.
I ran into a problem with the 40 thou longer rod hitting the middle of the cam between the lobes.
Eh....anyone else have this problem?
Having a conversation with myself here....
I swapped the BM cam into another all stock hemi I have. Same problem. It's actually hitting the crankshaft.
Having a conversation with myself here....but I figured the problem with some help.
the crankshaft rod journal shoulders are slightly larger on the newer hemis. So they hit the lobes on the cam.
Where we live they refuse to run interent. All we have is our phones for Internet.
I can't post pictures with my phone to this site
Sorry
I'll have to shave on the rod journal shoulder
So you need to clearance for the crank then?
ive heard of clearanceing the cam lobe itself, if I remember correctly, its probably hitting the exhaust cam lobe and some have removed part of that while still leaving the shape/ profile
vwfan79
I would clearance the crank, anything taken off the cam lobe will change its profile. The crank can be clearanced with no ill effects.
not if its hitting the edge of the lobe, you basically make the lobe narrower a smidgen, still retaining same profile. w/o pictures, I'm guessing ...but I think thats what I have heard to solve the issue, just basically shave the one lobe wall down to clearance. removing metal from the crank changes balance, not that its precise now, but still....
vwfan79
I see what your saying, I would just prefer to clearance the crank then the cam. It's a predator your not gonna notice a little more vibration. Lol.
Must be just the newer Hemis... I got 2 bought last year 2014 with a 307, 308, and a 330 cam and all clear without a problem...
Depending on how much you have to take off it is better to clearance the crank. If you narrow the cam too much it will leave wear marks and possibly lead to premature lifter wear...
