So far I have modified my 6.5hp central machine clone with the following parts:
Governor removed
Header with rlv
140 emulsion tube and larger main jet
Uni air filter and adapter
0.020" longer arc connecting rod
Honda t3 flattop (1mm rings)
Arc 6619 billet flywheel
22lb springs
CM pushrods
Exhaust retainer with lash cap on intake
Wms fuel pump
Gx200 carb insulator with pulse
Grade 10.9 bolt kit
After Christmas I plan on installing the following parts :
Dyno mod 2 can
1.3:1 stamped rockers
Aluminum retainers and split keepers
Stock size SS valves
Hardened lash caps
14cc clone head
Head studs
0.045" fiber head gasket
22mm mikuni with long adapter,pulse, velocity stack and large filter
Does this seem like a reasonable next upgrade or am I going to have too much compression? Looking to run 93 octane . Any help is greatly appreciated!
Governor removed
Header with rlv
22lb springs
CM pushrods
Wms fuel pump
Grade 10.9 bolt kit
Dyno mod 2 can
Hardened lash caps
14cc clone head
Head studs
