So yeah I'd appreciate any and all comments again...
I'm modding a Honda rear wheel onto this Arctic Cat rear end, but these two are dissimilar enough in design that I'm unsure how best to stabilize the brake shoe panel. I'm only used to the kind of slotted brake panel housing that locks against a welded lug post on the frame, like inside the swing arm, or fork tube. But this Honda panel has a bolt for securing it to a bike, and I'm pretty much drawing a blank about how to rig it up here to be: 1) safe, and 2) not stupid-looking. So far my best idea is to just run a short flattish but angled steel bracket from the panel's fastener to the backside of the suspension assembly (ie: between the shock absorber bolt head and the inside of the swingarm). But how robust does such a bracket need to be? And is my swingarm going to be able to handle that stress? Will the 3/8" shock bolt end up sheared or bent? The original welded lug post on the frame is so much more substantial, ... it's even buttressed with an additional weld-on.
If you all could make out from the pictures what I'm working with, I'd really appreciate any ideas or advice you might have. I don't want to have to modify the frame significantly. Nor do I want to get into welding on it. In the pics, the panel is unsecured, obviously. But I set it to where I think it visually will blend in best, just kinda hiding in line behind the swing arm. And speaking of blending, I plan to ultimately paint the hub and brake panel black.
