I have a HS40 motor that has a little tiny spring push type button on the bottom of carb bowl. At first I thought it was a primer type button. However, when you push it gas flows out. So maybe it is there just to empty the gas from bowl when tank is shut off.
Regardless, I thought I read on here you can remove from the bottom of bowl and replace with a rubber type plug.
Is that true? Is there a link to this type of stopper?
any help would be great!
